440duster
Hey guys, is a return line necessary on a mechanical fuel pump? If not necessary, are there any improvements with it? I just finished my fuel cell install (see attached pics). I drilled the cell and put a -6 bulkhead with flare cap (so I don't have to drain it later) . Later, I'll be installing a Holley Blue pump and regulator which will definitely have a return.
Thanks!
Greg
Oh yeah, you can see the filler tube in one of the pics. My car is too close to the garage wall to remove the tube. It has no gas, so I can't back it up to pull the tube!!
Thanks!
Greg
