DusterDale
Finally starting to work on this 440, she turns over easy with a ratchet so I dont think im in for too much drama. The rocker arm shaft spacer between the sets wont slide off the end of the shaft ( I popped out the plug on the end)...im a little hesitant to just emery and make it cleaner till I run it by you kind folks hahaa any tips or tricks to this? Thanks in advance,
D~
D~
