Roller cam advice
74desertduster
Tucson AZ
So, I have a short block 360 that is a 1989 block. So it can run a roller cam.
I have been getting tons of good advice from folks here about flat tappet cams cuz that what I was going to go with.
But if I decided to go roller, what would be a good performing cam for this setup? And are there any low cost decent ones available?
360 bored .030 over
Stock Pistons..they are about .100 in the hole
1994ish Magnum heads
Edelbrock Air Gap intake or Cross Wind
Carter AFB 625 (can be changed if need be)
Exhaust manifolds into dual exhaust
I had settled on my flat tappet cam and was going to go with a Lunati 60401...but I'm only gonna get one shot at this and the roller cam/lifters is appealing.
Thanks to all!
Brian
There are some places that can regrind the old roller cores. I have a roller core if you are looking for one. You can have it free, pay shipping, if that will help you go towards a Hyd roller nd you can use it.
There's a guy on e-bay that was grinding the cams.
Call Brian at Indio Motor 760-342-2178 or 760-347-5493 and ask him for a recommendation. Great guy. Know or have an idea about what your expectations are for the engine. He may be able to have the old mopar core I have ground.
