[WANTED] sb 727 torque converter
I have a factory converter for a 340 The stall in a factory 340 car is 3000. most brake stalled at around 2800-2900 The converter you are asking for is a standerd low stall used in trucks. If you are using this in a car it will be a real slug.
The converter I have is from my Duster before the big motor install and is in good condition .Never a problem with the trans it came out of Kept in a converter box on the shelf. I install a 5500 stall for the cam I am using now.
I used 2200 converters in the past and was never happy with them. They are for towing only. and will kill most motors using a bigger cam when put in gear. also you will never spin one tire unless you pu ti on a jack. two tires will never happen unless on a lift.
A 340 governer will also hold the auto shifts to 5500 -6000 only available in 340''s and Hemi's and max wedge cars. This is a must unless you are shifting it manually.
Nothing like leaving it in drive and planting your foot on the accelerator and turning the tires though second. That is the way they were.
$104 plus ride Paypal. Steve I see you are close you can pick it up if wanted.
