12many
Got a used cam and lifters just pulled, less than 10k miles in three years use in great condition. Single pattern Isky 280 Mega on a 106LSA (typically the 280 Mega is on a 108 LSA) 232@.050”, .323” lobe lift (.485” with 1.5 rockers or .517” with 1.6 rockers) Ground with 4 degrees advance 102ICL. 68 degrees overlap. Lifters are Howard’s, all in order in the box. See pictures of each set of lobes between the journals. Stampings and etching on cam end is a mess but that’s how Isky sent it. In my application approx 12 in-hg of vacuum and a solid racy idle. This is a great cam. In 410 stroker powered non-aerodynamic van I ran 11.75-11.80’s @110mph +/- With impressive street manners. Torque-a-plenty! $150 plus shipping.
