otrAlive
otrAlive
used SB Mopar engine dolly kit with 5" casters. Zinc plated 10ga. steel 1200lbs. capacity, Made in USA. from photos, you can see the zinc plating has corrosion on them. Otherwise, dolly structure is solid. reduced the price due to cost of shipping. $50 plus ground shipping, lower 48 states only. ships from 20653. two separate boxes may get better cost of shipping due to size & weight.
