Hi All,
1. It's my understanding the water pump from a 273 SBM is the shortest water pump. [Mounting flange to pulley face. Milodon Hi-Flow 16251 is 4.75"]
2. What is the stock water pump height? and is it Cast Iron or Aluminum?
3. Which cools better? Hi-Flow from Milodon or the stock 273 water pump.
When I asked this question before some people told me the Hi-Flow pumps may not give the coolant enough time in my 3 row radiator to cool down
I will also be using a Shrouded DERALE 2400 CFM electric fan with a PWM variable fan speed controller
I am swapping from a 273 to a mild build 340.
Thanks everyone for helping!
