Sbp To Lbp Help!!!!!!
fordilac
okiedart
lake ozark mo
I have an 8 3/4 rear that used to have the sbp. I have now converted to the lbp. Does anyone know if it is possible to get 10x2 drums with the lbp?????
DOES IT REALLY HAVE TO BE THIS COMPLICATED!!!!!
You will have to re-drill yours. How did you convert? Alot of aftermarket axles are offset for the 2 1/2" brakes and you may need to change backing plates and brake hardware to 10" or 11" x 2 1/2.
I had redrilled my drums but I was not very pleased with the results,I guess as long as the hub centers it the wheel will pinch it all together
