Golden Scamp
My '71 scamp has been difficult to start lately and I'm not sure what the problem is. The car is basically stock, and I run a rochester 2GC 2 bbl. I say this because it is surely a fuel issue. After the car has sat overnight, it usually will turn over just long enough to suck down whats left in the bowls and then die. I've checked the fuel filter and manually throttled the carb and fuel is there, but even after priming the carb to get it to start, the 318 still runs awful for the first couple of minutes and requires lots of feathering of the gas. The 318 is original with 58k, so plenty of blue smoke comes with this process as well. After a smooth idle is achieved, re-start is not a problem, but would like to fix this as I have a cruise night coming up and don't want to be left high and dry. Thought I'd question the pros on this one. Thanks for your help.
