ValiantOne
Brand new in the box Superior Shift shift kit for 727, 904 or 999 Transmissions. Never opened components package. Everything is accounted for and in perfect, new condition.
From the manufacturer's website:
Shift Correction Package
This valve body kit deals with these problems: * Lockup shudder * Premature clutch failure * Premature band failure * Inadequate lube oil * Inadequate line pressure * Converter burn up * Weak 2nd and 3rd shifts
1. One kit does all 727, 904 through 999's, 1962 to 1995. 2. The Superior KTF-TC kit gives the option of choosing lock-up speed. 3. Delivers full time lube. 4. One kit will do regular, heavy duty and extreme heavy duty applications. 5. It addresses converter problems on all years. 6. An easy to use adjustment tool is supplied with each kit. 7. Case saving information is provided in this package.
Located: Williamsport MD
$20+shipping (looks like it would fit in small flat rate box)
Thanks,
CE
Thanks,
CE
