[WANTED] Shift selector cable.
RichB
CherryCuda65
South Carolina
I still need a shift selector cable from a 65 or 66 A body that goes from a floor shifter console to a 904 Torqueflite transmission. Mine is a 65 Barracuda. It should be the same part with any engine.
I just need it to have an intact covering or a small piece missing because these things will leak transmission fluid as mine is doing. Please dig into your stuff if you might have one. .
Please PM me if you come up with one.
RichB
I have a cable from a 1965 Dart column shift. The measurements are written over each cable in the pics. If the ends are the same and the lengths are close, I'm sure they would do the job. I have two sets so the other person I offered these to can still get a set. (BTW 66 does not use a cable shift set-up.) Let me know what you discover. Cheers - Mike
Mike,
Is the shift selector cable 20" ? I think the console cable I need is 41",
I need to get the length of my Park/reverse cable. Is that the 34" one you have?
I will get back to you. Thx
RichB
The shift cable is 20". Let me check the length of my pushbutton shift cable - it may be closer to your needs.
I just checked my Pushbutton Shift cable length and found that it is 41". It has the same ends as the one pictured. Let me know if you are in need of further pics.
So, your pushbutton shift selector cable has the same ends as the 20" cable and is 41" long? It seems that should work. Can you send a picture of it? How much do you want for one?
