Hey guys tonight my 68 Cuda 4 speed would not shift into reverse so I got under the car and I could shift it into reverse with the shifter rod. I went ahead and removed all 3 shift links off the shifter and still cannot shift into reverse on shifter (original Hurst). Should the shifter (with no rods hooked up ) grab all 4 speeds plus reverse? If so I guess my shifter is the culprit... thanks
