[FOR SALE] Slant 6 Factory OEM Harmonic Balancer
RustyRatRod
Caput villa stultus
Georgia
This is a very nice original Chrysler slant 6 harmonic balancer. I degreased it, blasted it, primed it with a thick coat of filler primer and sprayed it with several coats of gloss black. The rubber inertia ring appears in excellent condition and is not swollen or cracked that I can see and the outer ring has not slipped since the inertia ring is not distorted in any way. As you can see, it also has the hard to find A/C pulley in the back. That pulley had some light rust pitting, but all the rust blasted out and the filler primer filled them in pretty good. They were nowhere near rusted through. Again, this is a Chrysler OEM piece, not some chinkesium POS. That's masking tape around the crank snout. Also, that's not a chip out of the front of the balancer. That's where the factory machined a "bite" out for balancing. Located in middle Georgia. $100 OBO shipped to the lower 48.
Still for sale. I purposely made the flash and light exaggerate the pitted areas as not to hide them. They don't look that bad at ALL.
Or best offer. I don't sell junk. A new one is well over 100 dollars and that's without the hard to find A/C pulley.
