[WANTED] Slant 6 Power Steering Pump and Brackets
zrxslider
Active Member
Jensen Beach Fl
Rating - 0%
0   0   0
Need an original slant 6 Saginaw pump and brackets, Have a pump from a V-8 now and believe it has too high a pressure, makes steering overly sensitive. Need a slant 6 pump, mainly for the pressure regulator. Thanks
I have one with brackets and hoses. Dont know what it is worth. make offer. In Ga.
Can you send me a picture, so I can be sure I'm telling you the correct pump type?
Mine seemed too sensitive at first then I replaced with a new one and replaced everything for steering and still sensitive. Maybe u r just used too newer vehicle having a bit if tension or mine is just wanting me to do some drifting idk
