Gimike812
The head is shaved .080" fully rebuilt has engine builder valves, erson springs, ported and polished and has performance coatings on the valves combustion chamber and runners. I have $1200 into the head will sale for $850. Has never been installed since rebuilt.
Erson Pushrods NEW in box, $25 shipped to you.
Comp Cams Solid Lifter Set New in Box $25 shipped to you.
Offy 4BBl Intake Manifold used has been bead blasted and Primed in High Heat engine paint. $225
Slant six Electronic Ignition Conversion Kit used parts removed from a parts car has some wiring still attached. $150 Shipped
ARP Main Stud Kit PN 142-5401 New in Box, $50
ARP Rod Bolt Kit PN 142-6001 New in Box, $50
If you Buy Both I will Ship them for $100 total.
Re-curved and Rebuilt not Remanufactured junk, Electronic Distributor Have a Spec sheet if your interested I can get all the important numbers, its setup for a hot little car, $100
5 freeze plug block with a forged crank needs rebuilt, had excessive blow by found Piston was bad. can include the rods and pistons if you want them. $100 I know the forged cranks around here are getting harder to find.
I have lots of miscellaneous odds and ends if you are looking for a particular slant six item I may have it. I had 5 different slant six engines at my place at one time.
If you want more than one Item hit me up with a reasonable offer. I no longer am running a /6. These parts where rat-holed for a build that will no longer happen, just trying to finish my V8 swap.
ALL PARTS ARE IN Tucson AZ, I accept Paypal or USPS Money orders, All parts ship after funds clear, Due to work Schedual I only Ship on Wensdays and Fridays.
PM with your email or Phone number and I can email or text you pictures.
