[WANTED] Slant6 Power steering brackets.
I have one set... This is either a 65 or 66, but should be correct for what you are looking for... PM me if interested....
Those will work so long as you use the Federal style pump that is shown. If you upgrade to the more readily available Saginaw pump you will need a different bracket.
Thanks for the info great to know. Just can't figure the hole on top of pump as shown in picture?
