Slip Yoke Identification Challenge
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I have a slip yoke (not usable, too much rust) but I want to identify it any way.
Dimensions:
OD of slip yoke sealing surface 1.559"
ID of U-Joint hole 1.077" (small U- joint)
dimension between inner faces of U-joint 2.125"
overall length 6 7/8"
length of slip yoke sealing surface ~4 1/4" depending where yo measure from
splines, If you count peaks 25, If you count valleys 24, add double cut key-way to ether and I assume it equates to 26 spline
Numbers cast into the yoke 9 2 on one side, 2 3 & a triangle on the other
What does it go to?
