sloppy steering
ltrripp11
hey all
anyone know if the power steering box is adjustable for steering play on a 72 340 duster? got about 4 inches of play on my steering before it engages motor running. seems pretty sloppy...
Check the joint between the steering column shaft & the steering box first.
Watch the joint while someone cycles the wheel L/R with the engine off.
A Borgeson joint is the best cure, but the original assembly can be repaired / replaced too.
B.
