Sm block dist
35regal
This small block dist. Worked great, it has a quick curve to it, all in by 1500 rpm, also has adjustable advance , uses a allen wrench in vacum port, also comes with brand new accel cap, rotor. And used set of taylor wires, all worked, building a stroker, wont work with new dist. 60.00 plus shipping
Hey there...what engine setup were you running with this disty with all in by 1500? I have a stock distributor and it is giving me fits to time...this may work for me.
34o, solid cam, 4000 stall, 4.10, 18 intial, 35-36 total ,all in quick, 93 pump, makes it react when you hit the gas.
