[WANTED] Small block 360 Alternator brackets
wes beem
ohio
Need a set of alternator brackets, ordered one of the new fangled fancy ones from CVF racing and surprise, its garbage and does NOT fit like its supposed to.
Make SURE you get the right ones for your application- '69 and earlier cast iron water pump w/driver's side inlet v.s. '70 and later aluminum water pump w/passenger side inlet. Subtle differences...
