[SOLD] Small Block 727 Trans
73duster47
Fontana, CA
I have an A-727 transmission for sale.
Trans was set up for use with a lock up converter. Valve body has a Trans-go TF-2 shift kit installed. Trans should be gone through due to some intermittent shift issues I had over the 2000 miles that I put on it. Good core for rebuild. No converter.
Asking $200 but open to offers.
Local pickup in Fontana, CA (92336) preferred.
Dropping my asking price to $150. Local pickup in Fontana, CA preferred or I can meet in the area.
Will take to scrap if not sold by end of December.
Can you take a photo of the numbers on the side of the trans near the pan? Should start with PK.
Stamping on the side rail of the trans reads PK35158441 3366 9434.
This was not a lock up trans initially, it was converted to lock up.
I would buy if you were no so dam far from me, freight would be a killer.
How does one convert a stanard 727 for use with a lock up converter?
Very interesting.
Sold it this afternoon.
The guy that helped me build it made the conversion to lock-up was fairly simple from what I remember. Same case for both, just different front pump, cover and input shaft. One change to the valve body as well.
