femtnmax
Mopar 10.5 inch Aluminum small block bellhousing casting #2892482. Transmission bearing retainer opening enlarged to accept larger 308 bearing. Bellhousing opening measures 4.805" inside diameter. I used this bellhousing on a E-body, and clutch pivot attach holes are there for A-body also. This bellhousing is a slip fit over the trany bearing retainer; the machine shop set the clearance a little tighter than the loose fit used by the factory for better transmission alignment.
No cracks, all threads in good shape, no heli coils. Clutch pivot bracket included.
Info from Brewer's Performance: Mopar original 10.5" small block bellhousing cast #2892482 to fit 1969-71 A-body (will also fit 1972-76 A-body if BSB482 bellhousing ballstud bracket is used) and 1970-74 E-body 318/340/360 3 & 4-speed applications.
http://www.brewersperformance.com/proddetail.asp?prod=BH482
Asking $160 OBO including free shipping to lower 48 states. Paypal is ok.
PM me on this forum. The first buyer that pays owns it.
Thanks for looking.
Thanks for looking.
