zac_F71
I am probably going to finish up my 71 Demon's chassis this spring, and leave an engine trans combo for when it's done basically
I have -
small block 360 (1979 360block .030" over, nothing else just a block)
68 383 big bock - also ^ the same just no machine work yet - have 440 crank for it
small block 727 that works
big block ^ that is getting a stock refresh w/ a shift kit
Both of the above will be turbo'd ^ but run NA for a season or 2 while a turbo setup is built
I have a few friends trying to convince me to go 5.7 hemi in it with a turbo
but after pricing a full ^ swap ($6,000 with a GOOD fuel system) it costs more to do so than a built small or mild big block - and you have a stock 5.7 runner with 100k on it, making 320whp, as where the LA big block would make 350+whp - and bolt in with a mechanical pump, and swapping a few wires around
For stock, for stock, for stock the Gen3 hemi will make the most power - short of a 340 or 426 hemi - but either of those are out of the question as they cost to much when I already have the above parts
I have -
