dodgedude
COMP custom grind camshaft and matching lifters (solid flat tappet) for small Mopar. Specs are:
250/254 @.050 duration
275/288 advertised duration
.548/.533 lift with 1.5 rockers, .584/.568 w/1.6
LSA 104*
Has been drilled and tapped for rear pump drive, this does not affect its ability to be used with a traditional set up.
Lifters are in order, all looks to be in good shape.
Asking $100 shipped in lower 48.
Pictures will be added tonight. Here is a copy of the emailed specs that I received from COMP
Serial # A 7510 Spec Card# 047660
Part # 20-000-5 CAMSHAFT, CRS CHRY 273-360 FT
Core C20-4 CAMSHAFT BLANK, CRS CHRY 273-360 FT
Grind # CRS 6250/ 6408 S4 RPD
DURATION @ .050 INTAKE 250
VALVE ADJ INTAKE .016
DURATION @ .050 EXHAUST 254
ROCKER ARM RATIO
INTAKE 1.60
VALVE ADJ EXHAUST .020 LOBE LIFT INTAKE .3650
EXHAUST 1.60
VALVE LIFT INTAKE .584 LOBE LIFT EXHAUST .3550
VALVE LIFT EXHAUST .568
LOBE SEPARATION 104.0
DURATION .020
INTAKE C/L 101.0
TAPPET LIFT INTAKE 275 CAM ADVANCE 0
TAPPET LIFT EXHAUST 288 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 24 JOURNAL DIAMETER STD 1.951
VALVE OPEN EXHAUST 54 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 46 DEPARTMENT R
VALVE CLOSED EXHAUST 20
SPC INSTR FOR CUSTOMER
REAR PUMP DRIVE
Will ship from 82001, Cheyenne, WY
LSA 104*
ROCKER ARM RATIO
INTAKE 1.60
EXHAUST 1.60
DURATION .020
INTAKE C/L 101.0
REAR PUMP DRIVE
