[FOR SALE] Small Block electronic distributors and HEI conversion kit
smokinnjokin
Nekoosa, WI
I used a pertronix kit, so all my HEI stuff is up for sale.
1. Factory electronic ignition distributor with HEI 4-pin module, curved by Halifaxhops.
Includes the designed2drive HEI bracket ($20), mounted underneath with a GM 4-pin module, standard motor products LX-301 ($25). The module is brand new. Connections are crimped, soldered and heat shrinked.
Distributor is $180 without cap or rotor. That is exactly what I paid Ray (Halifaxhops) and you are getting all the HEI stuff for free.
2. SOLD New manufacture 'performance' electronic ignition distributor from Rick Ehrenberg's Ebay store. Paid over $90 for it. Advance curve specs are on his ebay page For Mopar Electronic Ignition Distributor A-Engine 340 318 360 Smallblock Dodge | eBay. $50 no cap or rotor. SOLD to coloradohill
3. E-core HEI coil (1.5 ohms) for use with the above distributor. Standard/ blue streak FD-478 with bracket, SS539 connector and 8mm coil wire to plug it in to your standard female distributor cap. $20.
4. HEI conversion wiring harness for small block w/points. Includes relay, 12 guage primary wires, with all connections crimped soldered and heat shrinked. Draws power from your starter relay terminal and uses the factory blue ign wire to activate the relay. So full voltage to the coil and module. Also includes a small pigtail to connect the factory eyelet on the blue wire to coil positive, in case you dont want to cut and crimp a spade connector. it mounts perfectly under the regulator on the bottom mounting bolt. Literally plug and play harness. It was a lot of work to make. $10
Shipping will be method of your choosing, medium flat rate box is probably easiest/cheapest for the distributors.
$200 shipped for full HEI kit. Curved OEM Distributor, wiring harness, coil, bracket and coil ignition wire.
Would you be willing to sell just the HEI mounting bracket seoerate with its 4 mounting screws 2 button head, and 2 countersunk?
Bump. Coil is gone, distributor with lx-301 4-pin module, wiring harness (plug and play relay w/ instructions) still for sale. Also found a cap with brass contacts to include. $180 SHIPPED via USPS priority.
