small block engine mounts question
74fldart
orlando, florida
is there a difference in the 318 and 340 , 360 engine mounts? i have these 2 mounts and need to know what motor they fit. i do understand they are late model spool type. thanks
340 & 360 are the same, the 318 is different. I believe the RHS on the 318 is in a slightly different position than the 340/360's
driver side enginemount ears on block is spaced wider apart on 318.s 318mounts work on 340and 360 with just a nut as a spacer...
hmm those mounts seems to miss the tube that the rubbermounts are pressed into
Kind of weird that they have "***" stamped into it at the end of the part number!!
Hopefully that is shorthand for "Assembly" or some UAW folks were screwing around that day
