[SOLD] Small block - fan, spacer and cast iron water pump
Machmeter1
Dayton Ohio
I am converting to AC and had to replace my direct fan and water pump.
The water pump has only around 900 miles on it and is from Bill Rolik Enterprises Water Pump-Small Block 64-69, 7 COOLING & RADIATOR, 3004763 - N.O.S., Reproduction, and Replacement Chrysler Parts (billrolikenterprises.com) -in very good condition.
It comes with a brass fitting for the bypass hose and a new Felpro gasket.
$ 35,- + shipping
2 3/8” Spacer is an original Chrysler part and in excellent condition. With the spacer come 4 correct bolts.
$ 20,- + shipping
18” Fan #2863213 is an original Chrysler part and in excellent condition. It was bead blasted and powder coated (semi-gloss black). There was no rust pitting on it. Attached is a picture with the number stamp before it got bead blasted. Rivets are tight and blades are straight – perfect condition.
90,- + shipping
Everything together - complete setup
$140,- + shipping OBO
All the parts came off my 1969 Barracuda with LA318 engine. I had the original fan shroud and radiator installed. With that water pump and spacer, the fan was perfectly located in line with the shroud.
Payment: Cash or Paypal
Fan and spacer are sold! Thanks
Waterpump with gasket and fitting still for sale...
$ 35,- + shipping
