Small Block Kickdown Rod
MOPARJ
What can I upgrade now?
Thousand Oaks, Ca
Rating - 0%
0   0   0
I am in need of a small block kickdown rod (from carb to main linkage that goes to trans only) for a 69 340 in my Barracuda. I used the one that was previously on it for my 4 bbl swap in my 75 Dart, leaving me with nothing for the Formula S.
If it matters, the trans is a 727, the intake is stock and the carb is an Edelbrock unit.
If you can't find one, I can make you one from a 2 bbl piece.
Just need to know length. Measure what you need and let me know...
