fishy68
Tyr Fryr's Inc.
Mallory Unilite Distributor # 3757901H for a LA. Very nice condition. Only has a few thousand miles on a new module and the cap and rotor have less than 1000 miles on them. It has an adjustable centrifugal advance mechanism and if I remember right it's set for 13 degrees of advance all in by 2200 rpm. In other words if you install it and set the initial timing to 20 degrees you'll get 33 degrees total by 2200 rpm. If your interested and want it set to a different amount of centrifugal advance I have a set of keys and will reset it to what you specify for no extra charge. I also have a couple extra springs to slow down the rate of advance if you like. I had it in a 360 with a pretty hot cam and it liked the advance in quick. If your engine has a moderate to large cam it too will most likely like the advance in pretty fast. If you have a mild engine it will probably like a little slower advance and I can install stiffer springs to slow it down.
This distributor has centrifugal advance only. No vacuum advance.
The only thing I don't have is the pigtail harness to hook it up but you can get it at Summit or JEGS for about $10
$125 plus shipping. It'll fit in a USPS priority medium flat rate box that ships for about $13 anywhere in the USA
I take PayPal, money orders, or cash. Located in central IL and local pickup is fine.
Pm me if interested and we'll work out the details
