Small block Mopar cast iron turbo manifold ???
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
I thought that sometime in the past someone here posted a pic of what looked like a stockish exhaust manifold that would mount
a turbo on a small block engine ???????
I see header single and dual one but not cast iron
Can't tell you exactly but you'll have more luck checking out the forced induction section.
My son used to have one for a BB, was made and marketed by an RV parts company. I forget who. Might be worth checking into for a SB?
I also remember reading a turbo conversion thread about a /6 and the writer/builder knew someone who could weld cast iron and cut a turbo flange from a 2.2/2.5 intake, cut the stock flange off the original/6 manifold and welded the turbo flange on place of the original flange.... Possibility in your case?
