[WANTED] Small block pulleys for crank and water pump......
Water pump pulley will be part # 2951836 For your reference. Good luck on your quest.
I have about 50-60 pulleys if anyone knows the height/diameter or part number to help her out I probably have it.... Also manual steering(single groove) or power steering(double groove)
I'm looking for a double groove pulley, but the groove closest to the harmonic balancer is a smaller diameter. I will try to get a picture of what I need! Thanks guys!
pic...not the best, I used my daughter's ipod to take a pic of the one on our Challenger and I stink at it! ha ha
Found a small block pulley. It has the shorter inner pulley. It is 2 1/2 inch high and 6 3/4 wide. I think it has an offset pattern 71-back so you may have to file that one hole to fit if you have an offset balancer. $40 plus shipping. Let me know if interested.
