Small block stroker windage tray
xring
WV
I'm using an 8-qt Milodon oil pan on my 340/416 build. Should I use a windage tray; and will the Milodon tray clear the stroker crank? Or can I just space the tray far enough away from the crank to clear it?
Thanks!
i did not put one in mine just the baffle in the moroso pan but you can use it but you will have the cut it up a little the clear the stroke .
