[Found!] Small Block Trans To Engine Support Braces
70_Mopar
New Member
USA
Hi- I'm in search of a pair of trans to engine support braces for a small block engine assembly Please PM, if you have a pair available.
PM sent here are pictures 904/318
I have studied 67,69,70.71,73 and 74 parts books, and they show that the 904 and the 727 use the same braces. But you need to know what year your engine is. Around 1976 they moved the bolt boss forward 1" on the driver side for the new longer starter. I think the original pad is still there, just not drilled and tapped.
I do not know what these fit. I'm sure they are 1964-1971 small block but can not remember trans? 904? 727? 4 speed? The OP is looking for 1970, 340, 727, A Body.
and there are two different styles that fit the earlier,
I have two sets that fit my 67 273/904
one set looks like moparfanatic56 post #3
and the other like 66fs post #6
I have no idea which is correct for what year.
Alan
