Small parts, random stuff
mopardude318
Gilroy, Ca
NEW 1 3/4" silicon radiator hose 90 deg...with 6 inch hose connector $25 Shipped
http://www.speedwaymotors.com/Straight-Aluminum-Hose-Connectors,8936.html
http://www.speedwaymotors.com/search.html?query=917-1010-1.75
NEW Milodon small block head stud kit $110 shipped
http://www.summitracing.com/parts/mil-80235
NEW offset spring hangers $25 shipped
http://www.americanmuscle.biz/35610_ADJUSTABLE_OFFSET_REAR_SPRING_SHACKLES_p/35610.htm
SFI rated flexplate for small block 904/727 complete with ARP flexplate bolts. Only used for mock up, never ran! $70 Shipped
Pre-1970 Alternator brackets $15 shipped
Automatic brake pedal assembly out of 68 barracuda $20 shipped
Cast iron 90 degree oil filter adapter $45 Shipped
One NEW felpro 1008 head gasket $30 shipped
http://www.summitracing.com/parts/fel-1008
Unknown Z-bar and ball stud bracket $10 shipped
Biscuit mount engine shims $10 shipped
Nice used mini starter $60 Shipped
Dougs 3 to 2.5" header collectors $25 Shipped
washer bottle $15 shipped
Hurst shifter, unknown shifter rods, hurst shift handle $60 shipped
New oil filter plate for magnum engine $7 Shipped
Or Buy whole lot for $325 Shipped :)
Located in Gilroy Ca 95020
damn james you coulda had your own swap space almost.i have alot of stuff too, next time maybe we could go in on one....
I would like the Z bar stud that's mounted to the large bracket. Is that the one that's 10 dollars?
I'm down for that! lol
Yes, however it is spoken for, I will let you know.
All Pm's returned...
Oil filter adapter sold
shifter & z bar sold
collectors and starter sold
milodon head studs sold
flex plate & arp bolts sold
