oldmoparsrule
I am selling the following items together as a package. I can fit everything into a Medium flat rate box for $14.30. I will sell this as a package for $35 shipped in the CONUS.
This is a universal driveshaft loop that sells for $24 on Summitt. I am missing the bolts that bolt up to the body. I was going to weld it in, so it did bother me, but know that you will probably need bolts if you are not a welder. ALSO, this is missing the other half of the loop. This was a swap meet purchase, and I did not realize it was missing the other half...bummer.
This is a used pinion snubber. It comes with the 2 bolts that bolt it to the housing. Blue tape in the picture is holding the bolts in.
The last part is two 8 3/4 axle end adjusters.
Thanks,
OldMoparsRule
Thanks,
OldMoparsRule
