spal fan to use
Buschi340
Wilhelmshaven, GERMANY
for a stock 72 Dart radiator ( net measures 57cm width, 42cm height ).
best performance spal to use, amperes they need and diameter. curved or straight blades?
how do you mount them? I don't wanna have pins thru the radiator net...
pictures welcome.
Thanks, Michael
Check what's out there in terms of newer cars. My buddy found that stock dodge intrepid fans flow 9500cfm!! Not bad and pretty cheap setup, he even swapped the motors with some vdo deals for more space and they now flow in the 10k range!
Dodge inteprid is not that common in Germany �� I currently have a ford fan which flows pretty nice but uses 40 amps which is not nice. Want a strong, light and less amp sucking one :)
Is that a Taurus fan by chance? If so, it's supposedly a good one for our cooling needs. If you run it through relays it shouldn't be an issue.
taurus we also don't have here. whenever fan starts the head lights are flickering. Also it burned the fuse box with 40 amp box. and it has a relais...
