Spark plug wires on fenderwell header setups
Oldschoolcuda
Early-A Body Nerd
Chesapeake, Va
What type of spark plug wires do you fellow fenderwell header guys run & how do you have them routed. Pics would be great. Have taylor wires with heat boots on my cuda now but would like a setup that looks cleaner.
Thanks
Oldschoolcuda
Accel 8.8mm just run straight along under the tubes and up at the front of the block and behind the alternator. 90° boots on both ends.
I have Taylor 409's straight boot, and the wires lay over the valve covers, and are pulled up tight to not get melted on the Hooker smallblock fenderwell headers
I have msd,s. Straight boots trimmed shorter, easier to get on. I use dilectric grease too. Have boots over them, pulled tight over the valve covers.
Still close to the headers, but no issues yet!!!!!!!!
Bob
64 Dart 360 w/hooker super comps..
I ran stock replacement type wires for years on a daily driver with a hot coil & routed them like moparlee. Never had a problem.
