Specialty Products camber/caster bolt kit
BrianH
Member
Woodruff SC
Does anyone have any experience using Specialty Products camber/caster bolt kit to achieve more positive caster? I understand the go-to solution is Moog offset upper bushings but the set I just received were seriously out of spec, .015" oversize on the outside diameter and .020" too long on the inner sleeve length, compared to the old ones that I saved. (never throw anything away!). And the washers that are supposed to fit inside the inner sleeve - not even close. On all 4 bushings. Sending them back to RockAuto and see if the replacements they send will be any good but I don't have a good feeling about it. Was thinking Mevotech bushings and the bolt kit but want to see if anyone has tried the SpecialtyProducts kit. Thanks in advance for any replies.
Brian
The slots in the mountings determine the amount possible, but I've seen slop between the cam & abuttments that have been damaged that prevent full adjustment, maybe the eccentrics are a tad oversized & slots are to be opened in length? They look good/ HD.
We all know where they're made. I'd trust 60 year old Chrysler parts before those. Bad things happen if an upper control arm bolt breaks. Also, most times, the flanges that the eccentrics contact are "rounded" out because stupid people try to adjust with the weight on the tires. Most times, you can increase the travel simply by straightening those flanges out.
