nates68
I have seen the 5" Auto meter gauges in the stock dash holes, but I plan on using the Speedhut gauges and they seem to be much thinner as far as mounting depth. Also, the largest diameter Speedhut has is 4 1/2" so I'm not sure how they will fit in the rally dash holes.
And, I plan on running a quad gauge on the right and speedo on the left like factory; the largest Speedhut has that in is 4", so I guess I have to run 4" gauges.
- or ditch the quad gauge idea, run the 4.5's and some smaller gauges as well.
Just wanted to see any installs, advice.
Thanks
Nates68
Thanks
Nates68
