SpeedMaster Black Friday is here
69FBCuda
Stand back 10' for your viewing pleasure & Safety
Florida
Enjoy
Speedmaster™ - Automotive Aftermarket Parts & Car Manufacturer
Looks like the sale doesn't include the bare casting heads this year.
I'm not sure if the promo has been applied to the web site yet. My thought was it would be done Friday and delayed until then to make the sale "official"
Hopefully, for the sake of people looking to get some bare castings, that’s the case
What are the general thoughts on other SM parts, valves, rockers etc?
Would they work on 273 Sean? Or would cyl have to be notched?
Steve....I have a set of Speedmaster heads I bought from another member here years ago. When I was doing my 273 for the 65 Barracuda, I bolted one to my bare 273 block and turned it upside down to look. Intake valves overhang the block about a mile! You would need to notch the block to use them. I had a set of later model 302 heads, so I took them to @NC Engine Builder and he reworked them for me and put 1.88 intake valves in them. They worked great on my 273 for what I wanted it to be. Mild motor, but it made 260 HP and 280 lbs of torque on the dyno.
:thumbsup:
:thumbsup:
Did you do a build thread on that engine? I wondered how that project ended up!
Thanks, and once you notch it, I would assume head gaskets could be an issue?
I think a 273 would probably require a notch with the 2.02 valves. But I'm no expert on 273s
:thumbsup:
Yeah, they are designed around a 4" or larger bore, so that would not be ideal either, although it can bolt on and work. For a 273, I'd be more inclined to use the magnum iron replacement, and drill them for the LA pattern. But they dont look very factory
I would think it would. That's one reason I shied away from them, or stock 2.02 J heads. I had to scrounge around to find the thinnest head gaskets that weren't for way too big of a bore, so to not lose compression in the void between the fire ring and the cylinder bore. I used a Cometic .028 gasket set, with the smallest bore size they offered...which was 4.040. Most of the rest of their offerings were 4.100!
Sean...could you get 1.88 intake valves into a Magnum head without sinking them too deep? I thought of that, but the 1.88's in the heads we fixed were right on the ragged edge with the .030 over 273 bore. I was afraid the 1.92's of the Magnum would need a notch too.
Probably could put a seat insert in there, and put the 1.88 on that, but then the bowl "might" be a little large. Interesting thought though
I always wonder.... they show the bare casting magnum replacement head as 179cc and the bare casting aluminum head as 170 cc.... I wonder if that magnum head as cast flows better than the aluminum head as cast....
Pricing is live for a set of non-CNC small block heads. $714 delivered, a whopping $14 increase over the first set I got three years ago.
I had my shop go through my last set of loaded heads. He said the castings were excellent, and the hardware was quite good. More than adequate for the kind of fun cruisers in my fleet.
