[FOR SALE] speedometer gears
I have a standard automatic A904, 1971. Which pinion is the standard numberr of teeth gear? If I want to slow down the speedo do I go with more or less teeth?
Less teeth.
Which is the standard number of teeth on the 71 A904 AND
What is the price
I took out the pinion and found that the A904 has a 29 tooth pinion in it stock.
Less teeth.
After much thought, I think you are in error, the more teeth on the pinion makes it revolve slower, thus making the speedo slow down.
Please correct me if I am wrong.
I took out the pinion and found that the A904 has a 29 pin pinion in it stock.
Is that $25.00 for each smaller toothed gear and $35.00 each for the larger tooth gear or for the group of gears listed next to each price? If it's for each group of speedos I'll take both groups for the asking prices. Let me know.
Carl
