[SOLD] Steering column floor shift A Body
Logan75
Member
Nebraska
Rating - 0%
0   0   0
Power steering length A Body column for floor shift car. No steering wheel or horn button or coupler,includes ignition key & turn signal switch lever. Black in color came out of a 1973 Sport Dart. $150 plus shipping I’m in central Nebraska.
will this work in a 1968 Dodge Dart power steering car and connect to the gearbox.I'm new to this stuff and was not sure if it will work in my car
Technically it will work BUT it's wrong because your Dart has tye ignition switch mounted in the dash where in 1970 and up, the switch in incorporated in the column. 67-69 a body unless there's some differences I'm unaware of. Hope this helps.
Hey Logan can you look under the plastic cover that surrounds lower column tube...I wanna know if the mesh that surrounds tube and shaft is oval slots or X pattern mesh cage
