steering column removal
canajien
Toronto
so close yet so far, after struggling for an hour my column has only cleared the notch for the roll pin
I ended up using a couple of wrenches as spacers, and using the largest pickle fork I have as a motivator but at this point it won't go any farther
right now its soaking in knock r loose for the night, and I'm looking for some other ideas and wisdom before I get at it again tomorrow morning
maybe a pickle fork with a 3 foot handle for leverage ;)
you seem to know what's up but i just have to ask.
the column is free and clear from the firewall and underdash attachment, correct?
I dealt with this issue a couple of weeks ago. We used wd40 and a hammer and tapped on the bottom of the coupler upwards. It was slow going but it eventually came free. I still had the seat in the car and rested the column on a crate to raise it and relieve some tension at the coupler. There may be better ways but it worked for me.
I opened up the coupler. Couldn't even get the roll pin out. Basically pulled the box first.
I'm gonna combine these ideas and see if I can get an extra set of hands today.
I've tried pulling on it from inside by myself, but
however, if I can get someone inside to support the wheel while pulling on it I can tap on the coupler...
worse case scenario, I finally have the excuse to order that new 16:1 box from mancini ;)
SUCCESS!!!!
closest friend wasn't available, they were trying to get things done before the rain this afternoon
so I propped the column up on a crate
tapped the coupler till it started to clear the indent for the pin
got in the car and then pulled it out
only to see there was no coupler
which really explains the sloppy steering
and the coupler itself was empty, good thing I got that rebuild kit.
as I've stated before a lot of redneck engineering in this vehicle, a lot....
Thanks for the advice everyone!!! Enjoy the weekend!!!
