steering knuckles?
adams scamp
New Member
tucson
Hey I have a 72 scamp that I'm trying to build a road course car out of. I'm new to the mopar world, but I was wondering if anyone made knuckles for thar a body that allowed me to get more angle. I will also be drifting the car which I know a lot of you wont like but its what I like
More angle on what?
If you're talking about camber on the wheels, you don't need new spindles you just need some Moog offset upper control arm bushings. Or tubular UCA's, if its in the budget.
As an added bonus of the torsion bar suspension, as you lower the car with the torsion bar adjusters your camber actually becomes more negative. You just need the offset uca bushings to get your caster right. The reduced wheel travel shouldn't be a problem since you're building a road race/drift car, so I assume you'll be adding much larger torsion bars anyway.
There's several road racers on the board, and a TON of threads about how to set these cars up for road handling. Just a search away.
Cool thanks I will look. I was talking about steering angle though buy I appreciate any help get.
