[SOLD] still garage cleaning more added
Sedanman
67-9 Valiant specialist
chicago Il
66-8 full chrome horn ring with cracked Plymouth center,polishes up nice but has some minor pitting $50
67-76 black kick panels with insulation & all screws $50
69-76 dealer installed a/c hacked up console plate (offer)
early bullet rally centers BBP,no outter pitting & buttons in nice shape w/screws $150 obo
k frame to radiator support bracket $10
wiring harness & volt reg for swapping over to electronic volt reg $15
67-76 chrome brake & gas pedal kit $75
day & night mirror $20
Non day/nite mirror $20
66-9 A & B body bucket seat bottom side covers $40
67 valiant signet glovebox door $5
66-7 window cranks & washers $40
68-9 glove box door with button $20
67-72 abody manual washer pump it is complete with hoses & pump,it worked when I removed it. $20
66-8 very nice black wheel with non pitted full chrome ring & plymouth center $175
early rally centers BBP,no outter pitting & buttons in nice shape w/screws $150 obo
66-9 A & B body bucket seat side covers $40
front & rear duster/valiant bumpers with bumperettes,no dents,need buffing $300 pr
2 67 valiant rustfree fenders L&R $450pr red
1 67 AZ valiant rustfree pass fender $250 black
1 clean 68 pass side fender $150 blk
68 valiant signet trunk lid mint $100
67 valiant original shop & 2 67 & 1 68 owners manual. $50 for the shop & 10ea for the owners
2 68 signet trunk trims $40 each
68 rear seat top & bottom,need recover $50
68-73 valiant rear glass & trim $50
67-69 valiant DS door glass $10ea
67-72 bucket seat weld in support brackets $20
complete 2 & 3spd wiper motors $20ea & 2 spd linkage $20
8 3/4 nuts & adjuster 20 nuts $30
68 abody padded horn center blk $20
66&7 screw in speedo cable $15
2 sets of 67 valiant signet trunk trim clips
68-9 abody non a/c dash heater switch assy with sliders & cables,no broken tabs $25
2 bucket seat release rail loops $20
66-7 trunk plymouth emblem $10
2 spare tire hold down bolts & wing nut $10 ea
67-76 a body manual brake push rod & bolt $10
73-6 a body lower control arms w/ sway bar brackets. 1 has partial t bar still stuck in it. $50
67-76 a body front frame rails $150
67-76 inner & out rocker panels $50 ea
15x7 Magnum Gt wheels set of 4,not able to use dogdish,must use bolt in centers $300
67-72 duster,demon,valiant rear bumper decent driver,shines well $50 w/ brackets
68 abody engine harness w/ fender sigs,needs new fuse link $30
67 dart/valiant only windshield trim chrome corners,5 used,1 NOS $40 for all
64-5 valiant bumper jack assy $50
67-76 non sway bar lower control arms $50
/6 low mile T bars 891/890 40,000 miles $75 with seals
4BBl carb spacers & adapters,1 spread bore,1 4 hole & 1 open & many gaskets & metal shims $40 for all or $15ea
I have a new 1945 rebuild kit,2 1920 carbs,1 was rebuilt & is in pretty good shape,the other unknown condition but I'm sure a new diaphram is the most it would need. also a bunch of parts from other 1920 carbs I parted out $75 for all of it shipped.
the rebuilt 1920 is from early 70's,the other is 69 & under 1920
202/160 manley valves
I bought these used & never used them. I was told they are Manley 4 groove stainless valves. There is very minimal wear if any at all. $75 obo + ship
dart wheel base 904 to BBP 8 1/4 drive shaft $50
3 good used non a/c heater cores $25 for all or $10ea
2 69 & under 1 wire neutral safety switches $10ea
new replacement distrib elec pick up $10
1 67 valiant/cuda very nice complete wiring harness for engine,interior (valiant) & rear lights $100
2 Power brake booster rear linkage dust boots $20ea
Shipping is NOT included,will combine, if local your more than welcomed to pick up.
i am looking for engine side heater mounting plate and gasket for '66 dart
PM me as I may not be able to find this thread in future, thanks
PM sent
interested in the 66-9 A & B body bucket seat bottom side covers $40
LMK
Thanks
Matt
hi, you have list buckets seat side covers, are these the ones that cover the hinges?, if they are the 40.00 is that for both front seats? { 4 parts} I need only 1 pair {2 parts}would take 20.00 for 1 pair?
Those are long gone,sorry
