[WANTED] Stock valve body for 904, 1970 Duster
MopaR&D
Nerd Member
Augusta, GA
The 904 in my 70 Duster recently stopped working entirely, there was no line pressure so I pulled the VB and it has a massive crack in it. I just need a replacement stock VB in good shape I can swap the shift kit parts over to from my current one. I may consider an aftermarket one as well as long as it has FORWARD shift pattern, full-manual would be OK but I'd kind of prefer to retain auto shifting. Also not looking to spend much money I'm ultimately going to do a T56 swap so I don't want to put more than I need to into my 904 to keep it going until that happens.
Also I need a valve body with the later "rooster comb" (forget which year was the changeover) to work with the later combo neutral-safety-reverse-light switch. My current one is older and doesn't actuate the NSS properly so I've had no reverse lights which would be nice to have.
Pretty sure I have a complete 76 VB but don't know if it's out of a 904 or 727. If it's from a 727 you may have to elongate one of the holes in the separator plate to get it to bolt up to a 904. It's real easy with a small die grinder bit. If that interests you let me know
Late 70s 904 valve body 50 plus shipping
From one i tore down a month ago if you need any other bits.
