Dusterb318
- Joined
- Feb 13, 2006
- Messages
- 862
- Reaction score
- 2
I am running a set of March Underdrive Pulleys on my car right now. I have been experiencing warmer than I'd like to see water temps when sitting in traffic it was about 75 out the other day and I got up to 200* nothing really higher that that but it's a little warmer than I'd like to see. I have an aluminum cross flow rad (16lb cap), Perma Cool 2950cfm electric fan and a FlowKooler water pump. Once I start cruising the temp drops back down to ride the 180* thermostat. I know some of it has to do with the air moving through the radiator but I can't help but to feel my low speed cooling has something to do with the under drive pulleys spinning the water pump slower than normal. I wanna try out a set of stock pulleys to confirm this. I mean how much HP will i really lose by going back to the stock pulleys....maybe 5hp. I could switch to a 160* thermostat to open up the flow to the radiator sooner but that won't help my higher temps while sitting in traffic. Should I switch to a stock 8-blade A/C car water pump and ditch the FlowKooler pump? I honestly think it was a waste of money but it doesn't leak or anything so why change it out. I need to get a shroud on the fan but I know guys that run the same fan and rad with no shroud in warmer climates that don't have issues but he does have an electric water pump so he has a constant flow of water.....and a lot more radical motor to boot. I know my tune-up is good. It's not running rich or lean, the timing is dead nuts on as the burn on the plug ground strip is right on the bend. 16* initial and 34* total. I run about 70% water and 30% antifreeze and 2 bottles of Redline Water Wetter. I know the pump gas will run hotter than race fuel as well. So am I on the right track or an I worring about nothing?
