mtolley
cam is back from bullet. specs are: grind# cra 258/266-14hr dur@.050 208/214. lobe lift .320/.3250. lsa 114 valve lift .512/.520 w/1.6 rocker sound ok to you guys? need valve spring recommendation, dropin parts.
I'm in the same boat, I have a 90 360 and was thinking about getting the cam reground. What was the cost and let us know how the cam runs.cam is back from bullet. specs are: grind# cra 258/266-14hr dur@.050 208/214. lobe lift .320/.3250. lsa 114 valve lift .512/.520 w/1.6 rocker sound ok to you guys? need valve spring recommendation, dropin parts.
