Street Fire PN 5520 and MSD Blaster Coil?
coalman
Texas
Is there an under the hood tach that you can use to adjust the carburetor idle screws that will work on above???? Thanks a bunch...
Use a vacuum gauge. Or if you have a timing lite with a tach in it i have an OTC lite that i use .
Thanks, I have a vacuum gage, but I think the cam in the motor might not give me accurate readings. I used the tach in the car this morning, just some back and forth foot work. I think I got it pretty close. Thanks again, I will look up that OTC lite....
i have a solid lifter flat tappet cam in mine and the vac gauge works too. You can hear it as well.
