Strut Rod bushings
bbeep71
N Providence
I need to replace the strut rod bushings on 66Barracuda. What is easiest way to replace them?
buy the moog strut rod kit -- it has instructions on replacing -- very straight forward. Lawrence
Take it to shop, write them a check is probably easiest. But if you want to do it yourself the Moog bushings are easiest.
If the strut rod bushings are bad, how is the rest of the suspension? I've seen a LOT of cracked, dried out, "bad" looking strut rod bushings that were still doing their jobs when the rest of the suspension was totally worn out.
